Assembly import from SW, possible ??
I tried to import a complete folder originally made with SW 2014, part come in and translate OK but assembly cannot not be translated (which is a big bummer, sad face and all...), the drawing cannot either but i did expect that. Is there a way to do that ?? With the time i did spend doing those, it will be nice to be able to retrieve them. I'll say to make a final migration, that will be a must.
Thanks,
Thanks,
jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 664
We can handle pack and go zip files from SolidWorks if you make the pack and go with the default settings.
The video about it when we released:https://www.youtube.com/watch?v=kXROlfX6h04
Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
I believe there are problems being worked on with translation, but one thing to check is that the name of the pack & go zip is the same as the name of the top level assembly (which by default it is, from Solidworks, unless you type in a change)
The file gets imported, but no translation occurs. So I just end up with an uploaded zip file. I checked that the file name of the assembly is identical to the name of the zip file. I tried uploading from the documents window and from inside a new document. I got the zip file from someone else and there is a (very small) chance that the pack n go was not done properly. But, assuming that the pack n go was good. Are there any issues I should be aware of or common mistakes that I could be making?
Thanks!
