VisualCAMc Beta in OnShape (How to unselect all work regions before next operation?)
james_whittington
Member Posts: 12 ✭
I have been using VisualCAMc Beta for while now. I can create a simple part to be milled by a CNC router. Load it into VisualCAMc and generate G-Code. However going from pocketing a region to profiling a region. I have to manual click on every line to unselect. I found in the online manual it says you can press the space bar to clear selections, but nothing happens when I do that.
Basic Procedure
Selection works like a toggle. Click to select, click again to deselect. You can also use Alt+click to additively select and deselect (the same behavior you would expect from Ctrl+click). Clicking additional entities adds them to the selection set. Clear selections by pressing the Space bar."
Any help would greatly be appreciated.
MecSoft_Support
Member Posts: 10 PRO
Is this part specific or does it happen on all documents? Would you be able to check if this issue also exists with Chrome browser? We would like to take a look at your screen to troubleshoot this issue. You can reach us at (949) 654-8163 between 8 AM - 5PM Pacific Time. Thank you.
5 -
james_whittington
Member Posts: 12 ✭
I am happy to report that the function works in Chrome, i was able to de-select everything......Thank you so much for your sponse....I am going to remove fire fox and reinstall and see what happens with that
MecSoft_Support
The issue with deselecting all regions using Space bar in Firexfox browser has been fixed in the latest update VisualCAMc. Please verify this and let us know if you are still experiencing an issue.james_whittington said:I just doesn't seem to work for me......I click outside the part, and then press the space bar and nothing?I am using FireFox for my browser. Is there anything that I need to update?
1 -
james_whittington
Member Posts: 12 ✭
Yes its Fixed!!!MecSoft_Support said:
The issue with deselecting all regions using Space bar in Firexfox browser has been fixed in the latest update VisualCAMc. Please verify this and let us know if you are still experiencing an issue.james_whittington said:I just doesn't seem to work for me......I click outside the part, and then press the space bar and nothing?I am using FireFox for my browser. Is there anything that I need to update?0
I will schedule a demo in the very near future!
Thank you,
James
