Aligning a work plane with the front plane in part studio
paul_bartlettpaul_bartlett Member Posts: 92 ✭✭
How do I align a work plane with the front plane so when I do a drawing all my views are normal?
https://cad.onshape.com/documents/8d9f5c0e2c4a57afce0fba09/w/997f4032f21955ab97fa26ee/e/fad3e35d54ac0989206a4caf
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,861
    I think you are asking how to set up a view in the drawing? If so, create a Named View in your model to represent the "front view" and use that named view in the drawing.
  • paul_bartlettpaul_bartlett Member Posts: 92 ✭✭
    That could work but is there a way to align the work plane to the front plane. I need my parts aligned with the front plane the same way my work plane is aligned.. I am guessing I shouls have sketched it that way bt making my polygon concident to this point.
    I got it. I just had to edit my sketch and add a constraint.
