Need advice how to redraw from old drawing for laser cut productivity
dennis_de_klerk
Member Posts: 14 EDU
in Drawings
Dear all,
I'm a pit rusty on my CAD skills and picked up only a while ago. I've got the basics covered again and ready to start working on design drawings of a small RC model plane.
I've found a very old drawing (80ies), see pdf attached. My idea is to make a 3D model in OnShape of this plane based on this drawing. So far so good and it'll have the ultimate goal to generate drawings that'll allow most parts cut from big nested sheets using laser cutter.
My Question: what is the best way to generate Sketches, Parts and Assemblies:
Kind regards,
Dennis
- Should I make a Sketch for every piece, extrude it into a Part and then assemble those in an Assembly? As such I'm sure to have all individual part that I could put in a nested sheet of wood, but I think it'll take more time to position all parts.
- So would the alternative of sketching multiple pieces in one Sketch work, generating 1 (?) Part of those multiple pieces and thereafter make the Assembly? I've noticed it's easier with all the snap functions for example. And for sure this proces will be a lot quicker, however I'm not sure if I'd be able to make nested sheets of all pieces?
Kind regards,
Dennis
Next you can call entire part studio in the assembly, pick all the parts and apply group constrain. Looking at your example drawing sheet I understand that initially it will take considerable time to create your first sketch for all parts but in future it will help you very much when you need to change the position of any part in assembly. It is only required to change the position of part profile in the first sketch which will update in part studio as well as in assembly.
It is possible to create drawing for each separate piece which is created in multi-body part studio.
See this video link for multi part modeling
https://www.onshape.com/videos/multipart-design
https://www.onshape.com/featurescript
With a bit of modification you could put all of the standard balsa sizes into it.
The workflow then becomes simply a sketch of the fuselage side and then apply the 'beams' feature - specifying the balsa size for each member. All of the mitering and trimming is automatically taken care of!
Unfortunately all i hear around here is 'do some work' - don't they know this IS work?
Maybe you will be more successful
https://cad.onshape.com/documents/0696a1fdc81d963b1e805c90/w/b7b9c06655a1327e4c036d19/e/2030fa2a068a32e3151ea7e9
Speaking of painters and inventors of the Renaissance ... Do you know where the name "Close 2 Circle" comes from?
It seems that the Pope sent a messenger to ask for some proof of his skills to know if he was worthy to work for Rome.
"The value of this work will be recognized."
Like Giotto, we at Close 2 Circle look for perfection, simplicity, speed, the use of new approaches and new tools to optimize resources and simplify processes
Recently I started on a new model. Bit different approach using 3D projected lines. Basically I make, for example, 2D drawings of the fuselage from 2 perspectives and then use the 3D projected line command to make up the contour. I then built up a surface model and after it being solid I start drawing the insides like Bulkheads etc.
Not that I invented this by all means, but for the thread perhaps still relevant to note! I like this, because it keeps me in part mode a bit longer. I like Assemblies and in-context modelling, but in part mode often works simpler when working from an imported 2D drawing.
