VisualCAMc Beta in OnShape (How to unselect all work regions before next operation?)
james_whittington
Member Posts: 12 ✭
I have been using VisualCAMc Beta for while now. I can create a simple part to be milled by a CNC router. Load it into VisualCAMc and generate G-Code. However going from pocketing a region to profiling a region. I have to manual click on every line to unselect. I found in the online manual it says you can press the space bar to clear selections, but nothing happens when I do that.
"Basic Procedure
Selection works like a toggle. Click to select, click again to deselect. You can also use Alt+click to additively select and deselect (the same behavior you would expect from Ctrl+click). Clicking additional entities adds them to the selection set. Clear selections by pressing the Space bar."
Any help would greatly be appreciated.
OptionsMecSoft_Support Member Posts: 10 PROIs this part specific or does it happen on all documents? Would you be able to check if this issue also exists with Chrome browser? We would like to take a look at your screen to troubleshoot this issue. You can reach us at (949) 654-8163 between 8 AM - 5PM Pacific Time. Thank you.
5 -
Optionsjames_whittington Member Posts: 12 ✭I am happy to report that the function works in Chrome, i was able to de-select everything......Thank you so much for your sponse....I am going to remove fire fox and reinstall and see what happens with that
OptionsMecSoft_Support Member Posts: 10 PROjames_whittington said:I just doesn't seem to work for me......I click outside the part, and then press the space bar and nothing?I am using FireFox for my browser. Is there anything that I need to update?
1 -
Optionsjames_whittington Member Posts: 12 ✭MecSoft_Support said:james_whittington said:I just doesn't seem to work for me......I click outside the part, and then press the space bar and nothing?I am using FireFox for my browser. Is there anything that I need to update?0
I will schedule a demo in the very near future!
Thank you,
James
