How to make a smooth (paint)brush
Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 249 ✭✭✭
I try to make the brush of a paintbrush. I started making 4 splines and used them for 4 fills as well as for a loft. However, I do not get the surfaces tangent to each other. The 4 surfaces stay 'flat'. Who can help me to  make a smooth (rounded) brush?
https://cad.onshape.com/documents/38e1b581db7e3972b2b9b23d/w/c69e34d7ebda52fdd532e373/e/23b2ef61a6077970f5b17fe0
Henk de Vlaam (NL)
  • Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 249 ✭✭✭
    Hi @Evan_Reese,
    Thank you for your answer.
    I also tried myself too to add an extra profile sketch to the loft but that did not succeed, the loft did not generate. With your example I found out why. I did not Pierce the profile spline to the two projected curves but to the sketch lines. This because the proj. curves must be selected under Curves in the part section of the feature tree and not in the feature tree itself.
    So, I have a smooth brush now.
    Henk de Vlaam (NL)
  • EvanReeseEvanReese Member, Mentor Posts: 2,366 ✭✭✭✭✭
    @H_d_V
    Glad it helped!
