Onshape BOM
brian_pinder662
Member Posts: 119 ✭✭
I would like to use the Onshape BOM in the assembly of the helical stair I am drawing, however the part number and description columns do not appear to be working. Thought at first in could be that I am using Safari as the browser so tried Chrome instead but still did not work. Although the balloon fly out in drawings works fine in Chrome but not in safari. Can anyone suggest what the problem may be. I can understand the part no col as I don't actually have part numbers, but do have descriptions.
any help would be appreciated thank you. Brian.
Thanks for your reply Brian.
BTW if you are seeing differences between browsers, please report it. Thanks.
above url of assembly. Re differences between browsers, reported this some time ago and was under impression it had been addressed.
Many thanks Brian.
No problem with browsers both both up to date.
Sorry to be a problem, but could you take another look please. Brian.
However, you can show the name in your BOM instead of description:
Hope that helps!
All best wishes, have a good day. Brian.
