Sketching After Importing
robert_melascaglia
Member Posts: 45 EDU
in General
Hello
I just imported a model from Microstation as an STL file (and looks good). I now have the model in Onshape, created a Sketch, but cannot tag any of the entities (while in sketch mode). I want to move all the elements to the "origiin." Thanks, Robert.
owen_sparks
Member, Developers Posts: 2,660 PRO
Just as an addition to the transform function raised by @mahir when you say "tag" do you wish to have those points available in the sketch? If so the "Use" sketch feature will project them onto your sketch and they can then be used just like any other geometry. This is great for reverse engineering simple stl files back into solid parts. Things like the three point circle are great fro this.Cheers,Owen S.Business Systems and Configuration Controller
HWM-Water Ltd5 -
robert_melascaglia
Thank you gentlemen that was helpful. I have since used the "Use" sketch feature which allowed me to proceed.
1
