Connecting different sketch planes to make a 3D frame with fillets?
Strebs
Member Posts: 4 ✭
I have been trying to make a tubular steel chair. I have been attempting this by doing one plane and then doing another. However I'm not sure how to join the two sketches together so i can add a fillet to the corner. I am using the custom feature beams to make the tubes. Should a create the sections in different part studios and if so how? or am i missing the obvious here?
NeilCooke
Moderator, Onshape Employees Posts: 5,930
Hi @Strebs welcome to Onshape! I would not use the beams feature for this - a simple sweep of two circles would create the tube you need. The "path" the tube follows can be created in a number of ways - two sketches would do it (side profile, then the back piece running along the floor, then mirror).
Senior Director, Technical Services, EMEA5 -
philip_thomas
Member, Moderator, Onshape Employees, Developers Posts: 1,381
@Strebs - something like this perhaps . . .
https://cad.onshape.com/documents/f011cd888c79161a9fd3568c/w/fb24e71d7b9af8750059c2d6/e/b7f910d8f9b108542354bc28
Philip Thomas - Onshape2
