PATTERN INSTANCE VARIABLE
in General
I have many rails of different lengths that all have holes equally spaced along the length. What I am trying to do is model one of the rails and then use a variable to control the number of holes in the pattern. For instance, all rails have a hole .625" from each end then they have holes spaced 1.25" between those holes. I want the variable to take the distance between the holes at each end then add the correct number of spaced holes determined by the length between the end holes? Does this make sense?
Thank you for your help.
https://cad.onshape.com/documents/d748a4ebc28ac8c465b2eba6/w/4a867cab21e46273c6c1a05b/e/0b90dcb3487744b7bd94971b
I see how you did that. In our case the rail length is the known factor, therefore I was hoping to have it function by being able to change the rail length and then the number of holes would adjust.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/691a7028f1006301aa47baa0
Configurations will be my next challenge.
