Configurations and identical parts
brucebartlett
                    Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
                    I have a project which I am using configurations in the main part studio. This works great but only about 1/4 of the parts are changing with the configuration change but the configuration repeats the other 3/4 of identical parts with no indication. Is there a logical way here to use the default parts and not use the identical repeats or a way to automate this?
With this same part studio, I have parts that do not change in size but do change in position is there any trick to get around this when dropping into an assembly and group mating?
I am wondering how others are dealing with this when doing drawings and assemblies. Do you choose the default part to add properties and do the drawing with this and making sure this is selected in the assembly?
In the second situation, this will probably be solvable with assembly configurations. The trick right now is to prevent instancing in the part studio. If placement is important you can experiment with what I suggested above in terms of separating the parts but then configure a sketch or mate connector that drives part placement when changing configurations in an assembly. https://cad.onshape.com/documents/bd7a22090a9000c577f16178/w/1d7a24e00d9547000bc5572b/e/d9819ef6978a1defc0a84c2e
As a side note to @konstantin_shiriazdanov, keep in mind that this is a Part Studio configuration so it is very difficult to track individual parts and mark them as non-configurable
Twitter: @bradleysauln
I haven't tested this yet but one idea could be to add a configed delete on the non-default config for the non-changing parts, then we get a fail in the assembly for all but the default part.
