Sculpt Face not working
MBartlett21
Member, OS Professional, Developers Posts: 2,063 ✭✭✭✭✭
The sculpt face feature is not working for me. I used the U and V spline functionality, but when I drag a manipulator, it says that it encountered an problem (7f33a556e731919835b34e37)
The document is:
https://cad.onshape.com/documents/4a800579235f7a5ac7be93fe/w/38e6394f8a911bc0b84b84f9/e/a52bea4f2a3da0a319ff6457
@maximilian_schommer , could you help?
The document is:
maximilian_schommer
Member Posts: 32 ✭✭
@mbartlett21
@ankit_khandelwal
https://cad.onshape.com/documents/b8730d44070bc0466ad80444/w/b111d39908fbb971f1521124/e/d31d352b7aa2783efde5d023
Ok, I think it's fixed. It seems that annotations can no longer take in dictionaries as default values, but require strings. All of the manipulator values were stored in dictionaries passed through a hidden parameter, so that explains why the bug was occurring when you moved the manipulator. Try out Release 3.4, which should work now ( I could have just fixed it for my test cases, which wouldn't be great), and tell me if there are any problems!
Max5
https://cad.onshape.com/documents/26e97675846879236e5cafe0/w/afdff396d9f3d1389a0d289f/e/23dce50ccd19139ffa1b2225
Thanks for telling me! I'll try to get to it this weekend if you can wait that long. I'm not sure what the underlying issue is, but hopefully it's simple.
Max
@ankit_khandelwal
Max
Thanks! It works perfectly!
