Extrude Interactions
robert_melascagliarobert_melascaglia Member Posts: 45 EDU
Greetings
Can someone indicate why in the 1st image the extrude of the vert-member cut out the entire volume of the horizontal member?  The 2nd image shows both members to be in the same plane, and I extruded the horizontal member first; which of course, did not have the cut-out.  Thanks, Robert.
  • robert_melascagliarobert_melascaglia Member Posts: 45 EDU
    Grettings
    Seems I also have a space as the vert-member did not go to the construction line as I intended; but in reality, it is constrained there by the point.
    Very perplexing, but intriguing, thanks, Robert.
    Construction lines do not for "regions" they're just for referencing to or from.  Extrudes work on regions.  Make the geometry you need from solid lines and you'll be good :+1:
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    If you edit your extrudes you can add that missing profile to your selection. Here's a random screenshot of one of my extrude features with multiple profiles selected.
    Twitter: @bradleysauln
