How can I create a funnel between two parts?
chris_cartwright
Member Posts: 3 ✭
Link to document:
I want to merge the parts Top and Part 3 via the two surfaces created. I've looked around and most posts say create a surface then use Thicken, but I have an irregular shape. The top of the funnel is wider than the bottom of the funnel. I also tried the Fill tool, but it just gave me the message 'Sections do not enclose a region'.
Thanks
owen_sparks
Member, Developers Posts: 2,660 PRO
Personally I'd loft a solid then shell it, or if the top and base are concentric then a revolve would be easier.Owen S.Business Systems and Configuration Controller
HWM-Water Ltd5
http://www.youtube.com/watch?v=opPz9UiTEHM
https://cad.onshape.com/documents/e1971d0ab7572c1320250410/w/e1bab177aa71d0e45dc29cb7/e/5ea428184de9ac4186cec82c
