Forced snap of leader is different for different views
john_P37
Member Posts: 26 PRO
I have an object with a face at 45 degrees to the xyz axes. If I show an auxiliary view, and want to add a Note with a leader to explain something about the surface, the leader is forced to snap to an edge. On the regular orthographic views (front, top, side), this does not occur: I can put the leader anywhere I want.
The same problem occurs on the isometric views (which is where I really need to do this).
Workaround is not obvious to me at this time.
Thanks for any comments.
John
John
