Relations don't display for extended time
Not sure if I'm wording this right. I'm going through a few practice exercises in Onshape. What I realized is, when I hover over the constraints in a sketch, the elements involved in the constraint are highlighted, but then it disappears quickly. I have to move the cursor and hover it back on to the cursor to see the highlighted elements involved in the constraint. I would like this time period to be slightly more, is there a setting somewhere that could change this? Has anyone else encountered this problem before? Any suggestions would be appreciated. Thanks.
Edit. This is happening only to few constraints. cant figure if it's because they are overdefined or they are coincident constraints. Also is there any way to space out the three constraint symbols shown. They look too cluttered and it's difficult to see which one I have selected
You can drag the constraints around if they are getting in the way
If you check the "Show constraints" option in she sketch dialog, they won't disappear. Once you click that, you can follow @mbartlett21 's suggestion to drag them around to fix the clutter.
