Older Improvement Requests...
Don_Van_Zile
Member Posts: 195 PRO
Thought I would go through some of the much older IR's to vote on and thought I would share some thoughts.
https://forum.onshape.com/discussion/1467/add-option-to-view-mates-for-a-specified-component
This says it's "completed", but I beg to differ based on the request. I want to be able to select a Part(s) and specifically show their Mates via the Parts List or Graphics area RMB.
So I voted for @Tony_C_ idea below...
https://forum.onshape.com/discussion/6444/right-mouse-button-show-mate-connectors
This is becoming an annoyance/hindrance not being able to select a face that's been sectioned to drag and move Parts based on their mates.
We still need commonly used Port Holes such as NPT standard holes added without the need for custom FS that still isn't available, but this idea below is marked completed with 27 votes.
https://forum.onshape.com/discussion/6033/expand-hole-feature-capabilities
This request for Assembly Level Pattern (marked completed with 27 votes) is marked complete with the addition of the Replicate command, but I think most users would rather have the Derived Pattern functionality/idea from @john_mcclary below (See discussion in link for more details)
https://forum.onshape.com/discussion/1445/assembly-level-pattern
https://forum.onshape.com/discussion/9911/derived-component-pattern-assembly#latest
https://forum.onshape.com/discussion/6049/dowel-pin-symbol
This is still a BIG limitation for adding Hole Callout dimension's within a drawing.
@owen_sparksbrings up a small but noticeable UI behavior I've noticed too; it's a UI annoyance to be sure that could be improved.
https://forum.onshape.com/discussion/4273/transform-by-mate-connector-2nd-mate-field-auto-activation
I've noticed the lack of "Auto-Advance" with adding a Mate Connector Between Entities too. There may be others, but these workflows can be improved.
You forgot to link @owen_sparks IR.. Here it is (plus 1 vote btw)
I have also found this annoying, but I can understand on some places because you can select multiple entities in some fields, but this isn't true across the board.
Thanks @john_mcclary - I added the link as well to the OP; good catch.
