How to make guides between sketches to be used with Loft command
martin_olesenmartin_olesen Member Posts: 24 ✭✭
edited August 2018 in Using Onshape
Hi, i am sure that it is me misunderstanding, but i really struggle to create the socalled guide lines, between sketches when i want to direct the Loft function to create a more customized transistion between es a circle in one sketch and a square in another sketch.
I know there is a onshape video showing, but i can not make it work......am i wrong i thinking that guide lines can be "attached" from one spetch to another.......i think it is my thinking which is wrong...:-)
Is there a very simple example showing the process of creating guidelines between sketches, and then using the loft function?
