Coincident showing as Horizontal. Is there s problem with "show constraints" or have I just lost it?
magnus_hammar
Member Posts: 18 ✭✭
Something weird is happening to me when editing constraints. It seem to me that the displayed symbol sometimes is wrong. Here I have a "horizontal" constraint that clearly behaves as a coincident constraint. I cannot see that I am doing something wrong... or?
Jake_Rosenfeld
@magnus_hammar
Maybe share the URL to your doc here?
https://forum.onshape.com/discussion/9107/forum-post-checklist
It sort of looks like you have a horizontal constraint between the point ant the horizontal line, which would keep the point in horizontal alignment to the horizontal line, which, yes, acts as a de facto coincident constraint. Maybe you're looking to put the horizontal constraint on the angled line? Not sure what the intent is here.Jake Rosenfeld - Modeling Team1 -
paul_chastell
Onshape Employees Posts: 127
Note that the icon is blue, not white, indicating a constraint to something outside the sketch. My guess is that the horizontal is showing a relationship to the origin, with that line being one of the default planes and therefore coincidentally coincident with the point. Pun intended. If you hover over the icon then Onshape ought to highlight what is at the 'other end'.Paul Chastell
TVP, Onshape R&D6
/Thanks
TVP, Onshape R&D
/Thanks
