Sketch plane - howto reference to edges of an existing object
wolfgang_maier
Member Posts: 39 ✭✭✭
in General
Hello,
i created a plane on a surface of an object. Howto use edges of that object that sit on the plane as reference for sketching?
When sketching all edges of the object are not selectable.
E.g. Creating a surface between 2 edges of that object.
regards
Wolfgang
Have you looked at the "use" sketch command? This will project geometry onto your sketch.
Cheers,
