Parametric Related - Adding Equations.
robert_melascaglia
Member Posts: 42 EDU
in General
Greetings
Lets say I placed a rectangle in a sketch, and dimensioned the short-side (w) ; could I then use an expression such as h=1.5w as the long-side?
thanks,
Robert
Variables are set using the Variable feature in the Part Studio. If you create a Variable feature before the Sketch feature, you can define w as whatever length you want, and then use "#w" as width and "1.5 * #w" as the length.
https://cad.onshape.com/help/Content/variable.htm
Cheers, Owen S.
