Is Linear Face Pattern supposed to work this way?
ethan_keller924ethan_keller924 Member, csevp Posts: 44 PRO
I made a toy example to illustrate something that is plaguing my current model. When I pattern the three internal faces, I seem to get a phantom surface that is connected to the top of the box in between the newly generated faces. A section view reveals that this is a surface not on a solid body. Here's the relevant screenshot:
As you can see, there is a surface that shows up at the top of the box. It would be helpful to know why this is happening, and if this is the intended behavior.
  • paul_chastellpaul_chastell Onshape Employees Posts: 127 image
    I took a look at the doc and there is something not right about this result even though the body doesn't appear faulty. It may be a problem with the tessellation, not the geometry. Regardless I would appreciate it if you could open a bug with Onshape Support, preferably referencing the original document where this is seen.
    Paul Chastell
    TVP, Onshape R&D
  • ethan_keller924ethan_keller924 Member, csevp Posts: 44 PRO
    @paul_chastell I just submitted it as a bug report. Thanks!
