Regarding part studio
in General
I have created multiple part in a part studio. Is there any option to split them into multiple part studio with features used for that part.
In filter option available in part studio can show the features used for a specific part. So that my question can be solve on this way.
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
@D8_Starpac
The short answer to your question is just that we haven't implemented that functionality yet; voting on the improvement request that Don has supplied will help us prioritize the work.
The long answer to your question is that it's very non-trivial to do something like this. While it is possible now to filter down the features that affect a part, extracting this part into a different studio is not as simple as just ripping out those features into a different studio. What if other parts in the source studio depend on those features? What if there is other geometry in the original part studio that the part in question references? When it is moved into its part studio, do those reference parts come too? There are lots of considerations here before we release a piece of functionality like this.
If the goal is just to represent each final part in its own part studio, you could use the Dervied feature:
https://cad.onshape.com/help/Content/derived.htm
Jake Rosenfeld - Modeling Team1 -
owen_sparks Member, Developers Posts: 2,660 PRO
Hi all,
If we assume we've duplicated a partstudio then it would be great if we could invert that part filter selection and then delete that new inverted selection. We'd then have a new ps with just the features required to generate the part we filtered for.
Sure it would still exist in the original ps so it's not a real move, but I think there might be value there.
Owen S.Business Systems and Configuration Controller
HWM-Water Ltd2 -
@owen_sparks
Imagine that you have a layout sketch and then an extrude, and the extrude creates two bodies, and then you edit those bodies separately in the same PS. If you then take the inversion of the selection of the features affecting the part the you care about and suppress them, you will be still left with the initial extrusion of the part you don't care about. The dependencies are not very easy to tease apart without a lot of under-the-hood processing.Jake Rosenfeld - Modeling Team1
@D8_Starpac - Please vote for this Improvement Request; you look like you would like to do what I ran into with regard to "Splitting up Parts by their respective features into new Part Studio's"
https://forum.onshape.com/discussion/10004/extract-parts-and-its-features-to-a-new-document#latest
and since @KatieHuffman brought it up, which is a good suggestion to better see the tree "Part per it's Features", vote for this IR too.
https://forum.onshape.com/discussion/comment/44268#Comment_44268
My question is if it is possible to filter for feature that affect a specific part. Why not splitting of multiple part studio is not available.
