Tangent and Pin slot both impossible to use
 dan_engerer
                    Member Posts: 63 PRO
dan_engerer
                    Hi. Tangent and pin slot almost never work intuitively, you usually have to try about 10-20 times before something works.
Question: What is the magic "trick" to getting Onshape's pin slot/tangent mates to work? There's no indication that order matters, but I know that it does.
Disclaimer: The solution should not involve the creation of extra mate connectors because that should not be necessary and no other CAD software requires so much extra work.
1
Twitter: @bradleysauln
"Pin-Slot - Mate two entities allowing rotational movement about the Z axis and translational movement along the X axis. (Rz, Tx)"
https://cad.onshape.com/help/Content/mate-pin_slot.htm?tocpath=Desktop Help|Assemblies|Mates|_____6
"Tangent - Select a face, edge, or vertex of one entity, then select a face, edge, or vertex of the second entity"
https://cad.onshape.com/help/Content/mate-tangent.htm?tocpath=Desktop Help|Assemblies|Mates|_____9
Examples like Brad requested would help with your specific use case. The tip I find useful is the first click of the Pin slot mate defines the "slot" meaning the X-axis of the first Mate connector is defining the slide direction.
The second click is the "pin" Mate connector. Even if the X-Y axes don't align, the first Mate connector (X-axis) determines the slide direction.
Some other quick tips for understanding the Pin slot mate. Don't be confused by the name, "Pin slot" mate- really just allows translation in the X-direction of the Mate connector and rotation about the Z-axis.
I like to compare new things to concepts I already understand, so to compare a Pin slot mate to Cylindrical mate- the Cylindrical mate translates and rotates in the Z-direction of the Mate connectors.
And remember you can always realign a Mate connector to a specific edge of a part. Say my slot was slanted in the block, I can align the X-direction to be parallel to the slanted edge by editing the Mate connector and choosing the Realign option.
As far as the Tangent mate goes, that is a completely different animal, and does NOT utilize Mate connectors. Instead you pick a face, edge, vertex, or sketch entity to be tangent to a face, edge, vertex, or sketch entity of another part. Typically I use the Tangent mate for cam followers or when a part should follow the surface of another. Check out the Hahn-Sternmotor which is a public document that is a good example of when to use a Tangent mate, the rocket valve subassembly follows the Cam subassembly with tangent mates.
I too struggled to get the desired results with the Pin Slot mate until I figured out the tip well presented by @KatieHuffman - Great Tip and Well shown.
dan_engerer is making a good point (even with the tip).
If I have an angled slot, but I need it's motion restricted to another linear direction (actuator driven with the Cam Roller), then it looks like I have forced to manually set the angle of the second Mate Connector shown in the gif below towards the end.I would've liked to to simply "Align" the Cam Roller's Mate Connector to the Slot (so it's not manually entered), but that's a current limitation so I'm forced the manual way. If that angle changes it won't match and "later" I won't know why.
This is my quick workflow, but after sometime with trial and error to be sure.
In addition, when it's complete it's not limited by the size of the slot (i.e. the geometry), but that's another IR.
https://forum.onshape.com/discussion/9725/assembly-mate-limits-set-by-geometry-rather-than-dimensions
In any event, we're still far away from something like this workflow it seems.
From your gif it looks like you are setting the primary axis, not the secondary axis to the edge of the slot, which is why the Mate connector did not rotate as you expected. The x-axis is the secondary axis entity. Let me know if this is what you were trying to achieve.
Was this Part (Pin) rotated to this position to get the angle of the Mate Connector (See arrow) to by default on selection prior? How was this "re-aligned angle achieved with respect to your "I edited the X-direction (secondary axis entity) of the Mate connectors that belong to the plate to align to each respected slot."
Adding or Editing an Implicit Connector it's in the dialog during creation.
Adding or Editing a Mate it's not in the dialog during creation:
You have to expand the Mate type and edit one of the connectors post-op in order to get to the "Realign" options.
Not sure what to make of this yet as I believe this was the source of a lot of my confusion. Seems like the workflow could be improved...
An improvement request to be able to edit the Mate connector position/alignment while still editing a Mate dialog would be cool though
Check out the mating tech briefings in the Learning Center, Mating Basics, and Advanced Mating Techniques. These might help you wrap your head around some of these strategies.
Thanks for the extra info again. I've watched those a few weeks backs, but am just now delving into an example I'm struggling with today to be completely honest and ironically this post from the OP.
I haven't been able to successfully add the 3rd Pin Slot mate (without overdefinig my current mating scheme I want) and simply resorted to a Tangent mate and it gives me what I want/expect, but I thought I would use 3 Pin and Slot mates.
I just ended up getting it working by putting the Implicitly defined Mate Connector in the Part Studio for the 3rd Pin Slot Mate aligned to the angled slot; my goal was to do it at all at the assembly level. The Cylinder Travel and Planar mate is to Position the Cam Follower and limit it's motion to left to right.
I think the planar mate and the pin slot mate named Cylinder Travel might be why its over-defining when you add the pin slot mate to the angled slot- (that is my guess without actually digging into the document). In almost all cases, you only need one mate between any two parts. In my example, I added a limit to one of the pin slot mates defining the pin in one of the vertical slots. That limits the motion of the cam follower, without need for another mate. If you are still interested in setting up everything on the assembly level (I think it can be done), contact support with the feedback tool so we can better assist you on this specific design.
You are partially right in that the planar mate was for "setup" purposes initially is just a redundant mate that can now be deleted without issue or change in behavior; it doesn't over define the system though (at least with my current setup).
I've created 3 versions in this document below. Please see the version name and its descriptions for my process to get it to work. I had to "manually" change the angle to 45 degrees which I don't want to resort to; I want to align it by physical geometry. I actually prefer to use the Tangent mate on the final angled slot now (limited by geometry which is optimal if done right so that the other 2 vertical slots can actually be designed "In-Context" with the motion limts with a bit extra for clearance), but there are issues with that which you can see by the dynamic drag behavior that make me question for use moving forward.
I've shared with doc with support as well.
https://cad.onshape.com/documents/d0a03b901314177801a61230/w/d32cac38c29a83f62046ff97/e/321dc4113b7c9fa80c2ff807
I looked at your document, and it seems your V1 WORKS version is close. I copied that Version and made some adjustments:
- I suppressed the planar mate and the tangent mate- for now.
- The first thing I noticed was your Mate connector locations, I changed the Mate connectors on the Jaw to be at the ends of the slots instead of the middle. Then I made sure the X-directions were aligned in the way I wanted the Jaw to slide (relative to the slot). I did a combination of realign and reorient secondary axis button to adjust the Mate connector alignment on the Jaw and Cam rollers respectively.
- I did move and unfix and re-fix the pins so that they both are at the bottom or top of the slot.
- I added a limit on the Vertical Bottom Pin slot in the X-direction.- I measured the slot length and used that to define the limit.- This limits the motion instead of the planar mate.
- For the Pin slot- Angled mate I first made sure the Mate connector for the jaw was aligned to the slot edge, then I edited the Pin slot mate and clocked the pin by clicking the Reorient secondary axis button, this gets the Mate connector orientation for the Cam roller correct.
- I deleted the other mates- tangent and planar, and extra mate connector.
I only have three pin-slot mates for the 4 parts, and the only value I inputed was the slot length to limit the motion. Let me know what you think:3 Pin slot mates- I shared you into my copy explicitly.
