Face Pattern by selecting Features
sebastian_glanzner
Member, Developers Posts: 462 PRO
As many of you already know "Face Patterns" are a lot faster than "Feature Patterns", especially when working in sheet metal.
The only thing that is annoying that you have to select each face to use this feature and when you change the features, you have to reselect the faces.
The blue box should state "Faces or Features to pattern":
I think it should be possibly to use "Face Pattern" and select the features in the browser tree.
Because if you select features, then all the faces are highlighted in orange already.
So does it still make sense to use a face pattern with selecting features?
