What Mate To use when Assembling a Rubik's Cube?
rpmolnar
Member Posts: 4 ✭
So I created all the individual pieces of a Rubik's cube along with the center tubular structure and assembled them together using the Fasten Mate. But I'd like to be able to rotate the various faces just like in real life. What is the suggested method for mating the pieces together for that?
TimRice
Member, Moderator, Onshape Employees Posts: 315
As Onshape currently does not support intermittent contact mates (like a no surface penetration mode for assembly motion) this sort of motion is not possible. If you can make your doc public and share a link we can attempt to approximate the intended behavior.Tim Rice | User Experience | Support
Onshape, Inc.5 -
rpmolnar
Member Posts: 4 ✭
Hi TimRice, Thanks for the feedback. The doc is public. Called Rubiks Cube. Is there some sort of unique id that I can provide for it?0
Onshape, Inc.
The URL of your document is what you're looking for. See this post for more info:
https://forum.onshape.com/discussion/9107/forum-post-checklist
The url is separated into three sections:
https://cad.onshape.com/documents/12312312345abcabcabcdeff/w/<a rel="nofollow" title="Link: null">a855e4161c814f2e9ab3698a</a>/e/<a rel="nofollow">a2594e5a9c489bfbb5ab8533</a> [ Document id ] [ Workspace id ] [ Element id ]IR for AS/NZS 1100
The URL is here:
https://cad.onshape.com/documents/7a3290419e6b6e2d4b9ee8fa/w/e110543848c10ac874a225c9/e/3d7f8e89ab8372d68e66fc2d
I created a version (V3) for this particular state for future reference.
