Align, Center and Touch in Assembly
Is there a way to use basic assembly constraints found in other CAD softwares like:
-aligning two faces
-centering two faces in a cylindrical face or two other faces
-touch between two faces
For example, I have a squared profile with round corners and want to align it to another profile or rectangular part. I also want to center a hole in the rectangular part with one of the slots in the profile.
I added some mate connector to the middle of the profile and at the corner but apparently I would have to do this in every single corner and every direction of the profile to be able to use them to align and touch.
Edit: Is there a way to fix a distance between two faces?
-aligning two faces
