Hiding parts in drawing....!!!!
Vaish
Member Posts: 15 PRO
So, I have a part studio with configurations. In one configuration of which I want to create a 2D drawing. In this configuration, one extrude feature is suppressed, which results in one part of the part studio being hidden. Now I created an assembly with this configuration(in which one part is hidden) and it looks exactly how I want. I want to create a 2D drawing of this assembly configuration. When I make a drawing with this assembly, the hidden part shows up which I don't want(Obviously!!!). How do I prevent this part from showing up in the drawing...
PLS help. Thanks
PLS help. Thanks
3dcad
Member, OS Professional, Mentor Posts: 2,476 PRO
I agree with @Vaish that we should be able to hide part also in drawings (we should put feedback to Onshape).Suppress vs. hide can easily cause issues and should be carefully thought when applying since hidden part can be used as reference for other stuff because the part is still there it's just hidden. Hide should be used only for seeing something behind a part. But if you create a configuration where part should not exist, then suppressing the feature that created it is the way to go. Note that suppressing a part breaks any existing references to that part.This can be 'supprising' if someone creates sub-assemblies including hidden parts and then you need to link those to main assy + drawings. Everything is good until drawings show all the hidden parts
This is why it should be thought from the beginning.//rami5 -
lana
Onshape Employees Posts: 746
There seems to be a little bit of confusion here.
If a feature is suppressed in a configuration it is not regenerated in that configuration, in case of extrude, the corresponding part/surface is never getting created. When a part or a part studio is inserted into an assembly it is inserted in a particular configuration. In case of assembly created before configuring the part studio it is a default configuration. Changing current configuration in the part studio will not change the configuration referenced by assembly.
If you insert into assembly configuration of the part studio with the suppressed extrude the corresponding part is not there to be inserted.
Now in pictures:
https://cad.onshape.com/documents/995af893b33c0063094d2011/w/984f1aeea98d82fc4657aa1d/e/72240809ec43ef33d359cd74
Configured part studio to suppress Extrude 2.
unsuppressed:
suppressed:
inserting suppressed configuration - no cylinder
inserting unsuppressed configuration:
Hope it makes sense
5
Now in pictures:
unsuppressed:
suppressed:
Hope it makes sense
