What is the best way to extrude (remove) part of a shaft and leave a key
TimLesch
Member Posts: 1 ✭✭
The goal is to extrude (remove) a small amount of a shaft as an insert but leave a key for alignment. I can't figure out the key part.
NeilCooke
Moderator, Onshape Employees Posts: 5,987
You want to create a keyway and a key? Once you’ve removed the keyway material, just create another sketch (or reuse the existing one) to create the key. Make sure you use the “New” option when extruding the key.Senior Director, Technical Services, EMEA1
You can also extrude the key as a "New" and then use Boolean feature (with keep tools box checked) to subtract the key from the shaft (optionally with some offset) to create the keyway without deleting the key.
https://cad.onshape.com/help/Content/booleanparts.htm
