How can I import 3d models from sketchup?
  • terry_pipkinterry_pipkin Member Posts: 48 PRO
    There are scripts you can install in Sketchup that will allow you to export files that can be imported into Onshape.
    Export it as an STL
    @Panos_Seoolas Please understand that sketchup is a polyhedral modeler. Everything from sketchup will be a mesh inside OS or any other geometric based CAD system. OS & sketchup are very different systems.
    SpaceClaim was working on converters to get all those triangles back into a geometric representations but it's hit & miss most of the time.
  • Alex_PittAlex_Pitt Member Posts: 76 PRO
    First, import to Blender: (https://www.youtube.com/watch?v=dxMsMt233Zs). Then export from Blender as wavefront (.obj)
