Unfolding Tab For Mobile?
NikNYCNikNYC Member Posts: 68 ✭✭
Is the unfolded sheet metal tab hiding or not yet available at all for the mobile version?
    Hi @nik_willmore
    The unfolded sheet metal tab i not yet available on mobile.  Sorry for the inconvenience.
  • NikNYCNikNYC Member Posts: 68 ✭✭
    edited October 2018
    I can access the tab for flat version using dedicated desktop browser apps for iPhone.
    Full Browser:
    ...but no browser lets me right click the part studio tab or the flat model to access DXF export. Puffin browser might have done that but spit up a WebGL error from Onshape.
  • Paul_J_PremakumarPaul_J_Premakumar Member, Onshape Employees Posts: 197
    @nik_willmore : Interactivity - selection or pan, zoom , rotate are not supported when running onshape via a browser on mobile. This is because the web interface is designed with keyboard + mouse and not touch events. While the graphics and UI will render, you may not be able to do anything else. Hence we do not recommend the use of the browser on mobile.
