Time Log for Documents
RT_AXIOMRT_AXIOM Member Posts: 18 PRO
Would be nice for Onshape to keep track of the amount of time spent working on a document.  Especially if you are a design contractor with multiple projects on the go.  Sometimes I could flip between several projects during a day, and do that for 5-7 days a week.  It makes giving an accurate invoice to my customers challenging.  I do my best to try and track my time from project to project but it basically comes down to a rounded guess at the end when it comes time for billing and invoicing.
With the branching and versioning and "unlimited undos", Onshape already keeps track of all your moves and edits, so why not just keep a running tally of time spent on the total project/document.  This could be as simple as an hours:minutes tally in the branching and versioning history tree.  Or possibly right on the main document page.  If you highlight a document in your list it gives you some basic details on the right-hand side of the screen like date started and last modified.  Could be a good spot for a "total hours worked on" counter?
This could also get a little bit tricky if you have a larger document where you have more than one project within a document.  Or maybe parts of the document are billed out seperately.  Could create a version in the document if you knew you needed to keep track of changes/revisions to a completed project you have already billed for?
These are just a couple of ways of doing it, there's probably a better ay and it needs a lot more thought.
Or maybe no one else has this problem...
Just wondering if anyone else has different methods of keeping track of design time for their projects?
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373
    It would be easiest to just have one project per document (this would also help with organization and best practices) and then use the versions and history to see the time stamps to bill. You could always use versions to "clock in" and out of the document for billable time
    Twitter: @bradleysauln
  • Stefan_DMSStefan_DMS Member Posts: 48 PRO
    If you can get enterprise Onshape there is a complete analytics section for all the recording and managing of documents.
    https://www.onshape.com/cad-blog/introducing-onshape-enterprise
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,059 ✭✭✭✭✭
    @bradley_sauln
    Is there a way to "minimize" the history at the top, as once you get past ~500 items, it slows down drastically
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 889 ✭✭✭✭✭
    @ryan_thivierge
    I made a punch clock on google sheets to capture time for a job that travels throught the fab shop. Basically you click on the button for the process you are performing then click "in" and it will record the time and date you punched in to the job. When done click on the button for the process and then  click "out" and it will record the time and date you punched out of the job.
    Use the link tab app from the app store to attach it to the onshape document you are using to capture time.
    You could modify for just CAD operation and you can link this google sheet to an onshape document.
    Just a work around I use. You will probably need to make copies for different projects and then restrict the sharing so you just modify it.
    Here is the link to the google sheets: https://docs.google.com/spreadsheets/d/1KxXXKMHEX12DPtbIRJjEK-15-MvyG02zRa0TJnhqfHI/edit#gid=0
    Hope this helps
    click "CAD" then "In" to record start time
    click "CAD" then "out" to record stop time
    use link tab to attach to Onshape document
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • William_DegeleWilliam_Degele Member Posts: 2
    Hey, I added a feature to the FTC Insert Tool Onshape app accomplish this. The video details how to quickly see the hours on any Onshape document. Please note that these are estimates based on how many and how often changes are made on the document and do not necessarily include time spent reviewing the model without making changes. If you were to charge money based on, I would recommend explaining how this is estimated to your client. Also note that you may have to edit the spreadsheet to account for more than 100 days.
  • jelte_steur814jelte_steur814 Member Posts: 507 PRO
    I also freelance, but still prefer keeping control over what time is tracked when, rather than automating it. What if i'm slicing or prototyping or sketching in 2D in other software?
    I use Toggl track (they have a free plan) which is awesome because it's cloud based as well and seemlessly switches between your devices.
    Moreover they have a chrome extension that integrates with Onshape for auto tracking, so this might be your solution. I just haven't used it for that so I can't comment on how well it will work
    https://support.toggl.com/en/articles/2206984-toggl-track-browser-extension
  • S1monS1mon Member Posts: 3,476 PRO
    It’s been a little while since I’ve had Enterprise to use its analytics, but when I did, it wasn’t very useful for time tracking for billing. It would report hours for multiple projects based on tabs being open. So if a person had project A and B both open, their time would be counted twice. It’s hard to say when someone is working or not when they are just looking at an Onshape document. Perhaps if you were very careful about browser tab management it would be better. I also put in some support tickets at the time, so perhaps it’s been improved. All this is to say, the automated tracking was only so good and a manual system (can still be online) is probably best.
