Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape, CAD, maker project and design.
Sheet Metal Fold
MBartlett21MBartlett21 Member Posts: 1,397 EDU
I am in the middle of trying to make a FeatureScript that lets the user "fold" a sheet metal part.
However, I am having trouble determining the rotation axis once I have split the underlying sheet metal model.
I have modelled up a sample cross-section of a sheet metal part here
I have determined the rotation axis using a sketch, however, I would like to make a FeatureScript formula to get the location.
@konstantin_shiriazdanov , could you help?
MB - I make FeatureScripts: view FS (My FS's have "Official" beside them)
«1
  • konstantin_shiriazdanovkonstantin_shiriazdanov Member Posts: 820 ✭✭✭✭
    Hi, I found raius "r" which is the horizontal distance from rotation axis to the line of length "l1", so you can transform this result in terms of coordinates of the rotation axis origin. Is that what was needed?
  • MBartlett21MBartlett21 Member Posts: 1,397 EDU
    Could you make it in FS code?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 1,394 PRO
    Now you're starting to sound like me XD
    edited November 2018
    I'm assuming the angle is in radians.
    Is that right?
    Also, what are c and g?
    Yes, in radians. In Featurscript you just need to get axis of the sketched fold line and transform it at the s+r distance in the direction, opposite to sketch plane normal.
    What do c and g mean?
    If you mean c and g in ctg(a/2) it is cotangens, you might know it as cot() function
    Oh ok.
    In Onshape it is atan().
    :confused:
    And i suppose tg() is tan()
    Yes, its a miracle that when even triginometric functions have different names, we still can understand each other :)
    Atan() should be arctangens, if it doesnt exist you can express it as ctg(x) =1/tan(x)
    I have got it working in my part studio and here is the FS:
    https://cad.onshape.com/documents/9f116620b0f6d04445f57293
    Nice guys!
    PS: look in the flat before and after.
    Nothing changes :)
    Perfect
    Are you going to add in bend side? or will it always be based on center of bend?
    @john_mcclary
    You should be able to use it for angles in the opposite direction now.
    @john_mcclary
    You just can't fold it directly from a flat face (I don't know why, so maybe @lana could help)
  • lanalana Onshape Employees Posts: 424
    You just can't fold it directly from a flat face.
    Operations in flat are not very FS friendly. We'll try to improve that in the future.
    @lana what i am meaning is from a sheet metal model without any bends
    looks like you are going to compete with OS devs in the sheet metal features implementation rate  ;)
    now you just left to add unbend capability for existing bends
    Well they are making a hem feature :) (click here)
    @lana
    It doesn't seem to work if the edge selected to be "fixed" is on the face that is bent. (The edge's id seems to change internally after the sheet metal internal body is split)
  • Jake_RosenfeldJake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,162
    @mbartlett21
    Are you using split part or split face?  Split part has to create new tags internally because it creates a new body.  This should be somewhat stable due to our tracking, but once it goes through the sheet metal system it probable loses that associativity.  My recommendation would be to split the face, and then use move face-rotate to rotate the faces in question.  You may already be doing this, I haven't looked into the code.
    re: hems, you found our big secret :)
    @Jake_Rosenfeld
    I am using split part, then boolean.
    The reason I found out about the hems was because, when I updated my feature to FS Version 937, it told me that that symbol already existed. :)
  • brucebartlettbrucebartlett Member, OS Professional, Mentor Posts: 1,758 PRO
    @mbartlett21 I love your Fold SM tool.  I just tried it with an imported dxf, but found it was able to do the fold but failed on the flat pattern.
    @Jake_Rosenfeld
    If i do this:
    var fixed = getSMDefinitionEntities(definition.fixedFlange)[0];
    // Split the part ...
    debug(qOwnerBody(fixed));
    It highlights the wrong side of the sheet metal part (the one that's going to be transformed)
    @brucebartlett
    You will have to make a flange somewhere on the sheet metal and select that as the fixed part.
    You can then use the bend feature.
    Once you're done, you can do an extrude+remove on the flange (the sketch you use must include the bend)
    @mbartlett21
    Sorry it took me some time to get back to you on fixed reference stabilization.
    I did:
     const bodyForTransform = evaluateQuery(context, qSubtraction(robustSMBodiesQ, qOwnerBody(fixed)))[0]; const bodyForTransformTrackingQ = qUnion([startTracking(context, bodyForTransform), bodyForTransform]);
    And then used bodyForTransformTrackingQ in
    var wallAttFace = qIntersection([qOwnedByBody(bodyForTransformTrackingQ, EntityType.FACE), qEdgeAdjacent(edgeForTransform, EntityType.FACE)]);
    Please see in this copy of your document
    https://cad.onshape.com/documents/747286511d2736b6ec7f42a9/w/8187e95388ab7c0019b24fb8/e/a4e55c145d68860ba4080549
    @lana Thanks!
    I also had to make my own function remapCornerBreaksForSplitFaces to deal with the walls that were split (It is based on remapCornerBreaks)
    @mbartlett21
    That makes sense.
    Thank you for extending sheet metal functionality.
«1
