"Operation cannot be completed as it would modify a saved version"
Tony_C_Tony_C_ Member Posts: 277 PRO
I'm getting this message when I try to move parts/assemblies using "move to new sub assembly" command.
Anyone know why?
  • Tony_C_Tony_C_ Member Posts: 277 PRO
    Guess I found a "fix"
    I was selecting via a window and encompassing assemblies to add to the new sub-assembly.
    When I manually selected each assemblies and parts in the instance tree window I was able to move what I wanted to the new sub-assembly.
  • Benjamin_DellalBenjamin_Dellal Member Posts: 8 PRO
    @Tony_C_
    I have the same problem, could you explain your fix? I am trying to move parts in the assembly tree but get this message.
  • raj_Onshaperaj_Onshape Onshape Employees Posts: 111
    @Tony_C_
    I suspect you might be trying to move a subassembly child instance and the subassembly is from a specific version of a document. You might have to open the subassembly in question in its own window and do the move operation there
    @Tony_C_
    Are you selecting the only the assembly and parts in the tree?  You just need to manual click on the assembly and not the parts within the assembly.
