Share button is not working
Royi_ARoyi_A Member Posts: 2 PRO
Hi All
I would love if anyone can explain why my Share button on the top right corner isn't working.
I'm classified as Admin so I should have access, even if I didn't I should still have the possibility to press the button... I get an "no entrance" sign when I float over it.
Can anyone explain me this issue.
Thanks
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,895
    Is that all docs or just some? If you were shared into a doc without share permissions it will be greyed out.
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373
    "I'm classified as Admin so I should have access, even if I didn't I should still have the possibility to press the button... I get an "no entrance" sign when I float over it."
    - As an admin, this is only true for documents owned by the company you are an admin of. With any other documents, you need the proper permissions as @NeilCooke stated.
    Twitter: @bradleysauln
