Sketches
miyah_hofermiyah_hofer Member Posts: 42 EDU
I made a sketch outlining a guitar head, all in one sketch. I wanted to have the tuners in a different sketch for other reasons, but when I try to delete the outline for the tuners and connect the body again, then exit the sketch the whole sketch disappears. I am wondering to how to fix this problem. https://cad.onshape.com/documents/3c3d5e2af852d06e8f124754/w/0ddde85d2e9273d2ca268376/e/7b65dfeecb155078afee9d98
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,988 image
    Hover over the sketch in the feature tree and click the eye icon. It is probably just hidden.
  • miyah_hofermiyah_hofer Member Posts: 42 EDU
    NeilCooke I know it's not hidden because all the fillets and extrudes that are connected with that are red which means it's gone or there's a problem.
    You still need to make the doc public :) Go to the share dialog and press Make Public
    NeilCooke I figured out my problem thanks for the help.
