Mirror / Add a "sheet metal" cardboard box
TransistorTransistor Member Posts: 11
I'm trying out Onshape with a cardboard box design using the sheet-metal features. I have started with a line on the Right plane, converted to sheet metal and added flanges and cut-outs. Making the right half of the box seemed like a good idea as it makes it easy to work on the inside faces.
The half-box is pretty much finished but I'm stuck with mirroring it. If I select Add and Merge with all I just get the (faulty) mirroring of the lid flap.
I'd appreciate if someone could have a look at the model and guide me through the fix. Many thanks.
