Problem with server cad.onshape.com "This site can’t be reached"
Hello, I can't sign in and use cad.onshape.com because it isn't loading and opened message "This site can’t be reached". I from Russia. Help please.
  • john_rousseaujohn_rousseau Member, Onshape Employees, Developers Posts: 407
    Hi @aleksandr_tolkachev. This is going to be a problem with your internet connection to our servers. Russia has been blocking ranges of IP addresses over the past 6 months to block access to the Telegram app. Sometimes their rules impact other AWS customers like Onshape.
    Are you at a business or school that would need to whitelist our service?
    You may have better luck using a VPN with an England or Ireland endpoint, assuming that it's legal for you to do so.
    Personally I use Hotspot Shield browser app when can't access OS directly
  • aleksandr_tolkachevaleksandr_tolkachev Member Posts: 3
    Thank you.
    IT manager checked  whitelist and your service already added. So the problem in Roskomnadzor
