import assembly into same document but in separated part studios
 eric_zhao867
                    Member Posts: 5 PRO
eric_zhao867
                    Member Posts: 5 PRO
                    hi,
We have some solidworks assemblies that consist of some customer design parts and some over the shelf parts. Is there a way to import this assembly and parts into the same document, and in the mean time separated the parts into individual part studios?
The "split into multi documents" option works to some extent. But I would like to have the parts all in the same document, so that I don't have to keep versioning individual parts and update them manually in assembly.
thanks,
thanks,
Quick answer on how to do this:
If you need parts imported in as their own part studios then export them out of SW as their own part file (or export the sub assemblies). Then import them into an Onshape document. This will give you control over how you want to split up the assembly on import and with our newly introduced replace you can easily swap it at the top level assembly whereas in the past you would just delete and insert.
Keep in mind, there are limits to what can be done with imports for any system especially if you want the part placement to be positionally accurate to the source assembly.
Twitter: @bradleysauln
"why do you want/need the parts in their own part studio:"
For two reasons: 1) these parts are designed individually in solidworks. If they don't have any relationships, it does not make sense to but them in one large part studio. 2) We often have hundreds of different parts, and may run into up to a thousand part counts. Having a thousand parts in one studio, make it very difficult for future editing.
"If you need parts imported in as their own part studios then export them out of SW as their own part file".
Yes. aware of this method. But it is tedious for hundreds of parts. Just want to know if there is any way more efficient.
You could import them all as separate documents, and then as you find parts that you need to edit, move those parts into the document containing the top-level assembly:
No need to move all the parts at once, just move them into the master assembly when you decide one of them needs an edit.
