Can't Scale Entity Without Scaling Entire Sketch?
Catseyeguy
Member Posts: 4 ✭
Hi,
So I'm trying to create a create a sketch with cutouts, but I'm having an issue. When I try to dimension an entity in the same sketch as the object, the entire contents of that sketch are scaled proportionally. This happens regardless of any visible constraints. The problem does not persist if another sketch is created in the document, but if the original object is copy-pasted into the new sketch, it happens in that sketch too. Can anyone help?
Here's a link to the document: https://cad.onshape.com/documents/1b0465216ff26c96b5edcd62/w/edea98239ba78fba47c91381/e/6803bcf223fd2cf0b11a43d8
Sorry, I don't think i'm quite understanding your issue.
If there is only one driving dimension in a sketch, when you change its value the sketch will automatically scale proportionally (as you noted). If you place a second driving dimension in your sketch, before editing the value of the first one, the auto scale behavior should not occur when you edit dimension values.
However, this is true for the first dimension in any sketch, regardless of how many sketches are in your document.
Did that help? If not, could you please clarify?
Best,
Mike
Here's a video demonstrating the issue:
Therefore if you don’t want it to scale just accept the system generated value on the dimension you added then edit the value afterwards.
