startTracking with sweep
MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,060 ✭✭✭✭✭
I am trying to do a tracking query on a sweep to get a face to put into opReplaceFace.
However, it resolves to nothing.
Here is my code:
    // Sketch
    var sketch = newSketchOnPlane(context, id + "sketch", {
            "sketchPlane" : skPlane
    skLineSegment(sketch, "face1Line", {
                "start" : vector(0, 0) * inch,
                "end" : face1Point
    skLineSegment(sketch, "face2Line", {
                "end" : face2Point
    skArc(sketch, "arc", {
                "start" : face1Point,
                "mid" : normalize(face1SkDir + face2SkDir) * dist * (shape == FilletShape.CONVEX ? 1.15 : 0.75),
                "end" : face2Point
    skSolve(sketch);
    toDelete[] = append(toDelete[], qCreatedBy(id + "sketch"));
    // Weld Faces
    var weldFace1 = qEntityFilter(startTracking(context, id + "sketch", "face1Line"), EntityType.FACE);
    var weldFace2 = qEntityFilter(startTracking(context, id + "sketch", "face2Line"), EntityType.FACE);
    // Sketch face
    var sketchFace = qCreatedBy(id + "sketch", EntityType.FACE);
    var sweepDef = {
        "profiles" : sketchFace,
        "path" : qClosestTo(qEdgeAdjacent(face1, EntityType.EDGE), distResult.sides[0].point),
        "lockFaces" : face1
    opSweep(context, id + "sweep", sweepDef);
    debug(context, weldFace1); // Resolves to nothing :(
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,060 ✭✭✭✭✭
    @lana
    Is this part of the function the edge of the sketch face?
    makeQuery(sketchId, "IMPRINT", undefined, { "derivedFrom" : sketchQuery })
    @lana
    How would I get the sketch id from a user's selection?
    Or can't I do that?
    edited November 2018
    @Jake_Rosenfeld
    What I was wanting was to allow sketch edge selection for my shaped flange feature
    https://cad.onshape.com/documents/602655eff016f183fc184978
    @mbartlett21
    Are you sweeping the sketch region and trying to track one of the side faces, or sweeping sketch edge itself into a surface?  If you're sweeping the sketch edge, you should be able to just do:
    startTracking(context, { "subquery" : definition.edgeToSweep, "secondarySubquery" : pathEdge });
    If you are sweeping a region into a solid, and trying to track one of the edges by user selection, it'll require some creativity.  Sketch edges are actually independent wire bodies which sit on top of the sketch regions.  Sketch regions have their own bounding edges, which are not topologically associated with the sketch edges.  If your sketch is simple, though, it should not be too hard to find the correct sketch region edge to track, based off of a sketch edge selection.
    Here is a document with an example of how to do both of the above things:
    https://cad.onshape.com/documents/aeead03c19e203f80f7a8a42/w/7860ea9de8207834674fd2b8/e/7ef5715b5172858bcbc526fb
    @Jake_Rosenfeld
    I am wanting to get the sketch face adjacent to the edge so I can do an opExtractSurface on it.
