Onshape + X-Carve : what are the options ?
jean_didier
Member Posts: 28 ✭✭
I'm planning to get a X-carve and I will love to use Onshape for modeling projects.Is there a good option to use the models for G-code ? I saw a lot off top of the line CAM partner for Onshape, but first how that will work with the software and second is there anything available more simple for home use ? Thanks for the help ! Cheers !
joe_dunne
Onshape Employees, Developers, csevp Posts: 198
Jean,
I actually own a Shapeoko2 which is the predecessor for X Carve. Today I have found MeshCAM works very well. Its simple and is reasonably priced.... I have cut a lot of 3 axis parts using Onshape to MechCAM to Shapeoko... Plastic, Wood, and Aluminum.
Easel3D is included with your machine. It works well. But it is a 2D oriented product. It really only works with 2D SVG. So if you wanted to use that, you can export a DXF profile from Onshape, and then use a online converter to convert the DXF to SVG.
http://image.online-convert.com/convert-to-svg
Joe Dunne / Onshape, Inc.5
http://www.vectric.com/products/learn-about-vectric-software.html
Mike
The Vectric software is quite good if you don't need production level toolpathing! Heck, if you need production level 2D machining, it's hard to beat Cut 2D 1.5
