Mate to use for a Cam
ShepRCSShepRCS Member Posts: 9 ✭✭
Hi All
I've built Combers Rotary engine which uses a Cam to create rotary motion.  It appears circular although it is not quite.
I don't think that there is a Mate/Relation I can apply that will make the engine actually work when I spin the shaft?  It would be a mate between the bearing and the cam ring or a relation between the piston and the model  like a rack and pinion but it needs to go up for 180deg and down for the rest.  Anyone with any ideas on this?
Here is a link to the model I hope (just copied the address bar from the model which I have made public)
Shep
  • ShepRCSShepRCS Member Posts: 9 ✭✭
    Thanks @Andrew_Troup I hadn't seen that thread.  Answers my question perfectly.  Just wanted to make sure that I wasn't missing an obscure use of something we already had!
    Waiting on Cam Mate then!
    Shep
  • kesava_prasad_t_dkesava_prasad_t_d OS Professional Posts: 9 ✭✭
    Eagerly awaiting a cam/path mate from OnShape.
  • Stuart_TodStuart_Tod Member Posts: 65 PRO
    @richard_55 , @kesava_prasad_t_d ,
    There is a post in the Improvement Request section for completion of the Mates Suite, including Cam. Head on over there and vote it up!
