Lofting with multiple plane, and sketches
How do I get a loft across all the sketches in the vertical planes using the first 2 sketches as guide lines. Here is a screen shot of my screen.
    Hi, if you post a link to your document it'll be easier to help.
    Cheers, Owen S.
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,144 PRO
    Try lofting from the base to a single point (top vertex), then add your guide curves in to pull the shape out.
