Best method for drawing a trailer frame made with 4” C channel
derek_stone
Member Posts: 4 ✭✭
I am new to Onshape and trying to create a 3d model of a trailer frame and then produce shop drawings for the guy in the shop. If I sketch it then use the beam feature, the dimensioned lines are correct in the sketch but the beam places the hoist beams at the back of the C-channel making the true dimension 22.5 to the front instead of 24”. Should I draw each individual piece and create an assembly?
TimRice
Member, Moderator, Onshape Employees Posts: 315
I believe the issue is the beams are by default on the centerline of the sketch line inputs. You can actually use the arrows to move where the beam is located relative to the input lines. See the animation below to view this:
Onshape, Inc.6
Onshape, Inc.
