A Task: to split a part
There is any three-dimensional object. Let it be the cylinder.
How can it be divided into several parts (not necessarily equal) , as shown in the picture ?
What methods are there (what tools can be used)?
There is a solid cylinder (gray in the picture).
I want to split it with a multi-surface object, like this:
1) is it possible to create multi-surface object ?
2) is it possible to make a split this way or I should use a hollow solid object with thin shell to split ?
3) how to make complicated (tricky) split ?
However, it might be easier to create your blue body as a solid, then use the boolean/subtract/keep feature to hollow out the grey part.
https://cad.onshape.com/documents/84d939daceef6a928b8abcba/w/9e0dafb21fbe2ec8b983bbdc/e/4866ed2f8f23d9058819bb8e
It can union surfaces together and cut parts with surfaces, etc.
