dont work example app-stl-viewer
On github (https://github.com/onshape-public) examples of work. However, when you try to run app-stl-viewer the app cannot get the model! Is there an example application that can export a model in stl format?
Is the document shared with the application?
I get error: {"message":"Unauthorized API request", "status":401} The same answer half the queries now receives the application "API explorer"
I'm currently studying the onshape API and I'm wondering what queries need to be sent to get the model and its parts. And also what queries are needed to download the model or its part in stl format. Do you provide any opportunities for drawing the model?
