Discrpencies in documentation related to using acos, atan and other trignometric functions
atharva_patwardhanatharva_patwardhan Member, Developers Posts: 1
acos, atan and other trigonometric functions return results in radians and not degrees while I was using feature script, though the documentation mentions otherwise
Documentation Link : https://cad.onshape.com/FsDoc/library.html#module-units.fs
    edited December 2018
    30*degree in Onshape is a value in radians because internally degree=pi/180*radian. so "degree" is just built in constant which is used to translate angular values from derees to radians
    It is correct. All units in Onshape are in meters and radians.  Therefore you will have to convert it to degrees if that is the units you want. It is shown in the docs as 90 * degree (which is the syntax you use to define a degree value) because that is easier to understand than PI / 2 radians.
    Sorry for the confusion.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,237
    The arc trig functions don't return values in degrees or radians -- they return *angles*.  They are internally represented in radians, yes, but that should only matter for printing it, doing crazy optimization, worrying about floating-point roundoff error, or not making the best use of the units system.  Most frequently the latter.  Things you can do with angles are adding them together, multiplying by numbers, comparing to other angles, dividing them by each other to get numbers, passing them to trig functions and receiving them from inverse trig functions.  You can also pass them to operations like opRevolve.  It doesn't matter if the underlying units are radians or degrees for any of those things and there's almost nothing else people generally want to do with angles.
    @atharva_patwardhan
    If you really need the number of degrees represented by your angle you can do something like the following:
    But like Ilya said, you really only need to do this if you are trying to print output to the user.  Otherwise, you can just leave it as it's ValueWithUnits (angle) representation, and it will remain useful for math, trig function, and input into Onshape operations.
