Multiple small flanges instead of one big one
Member Posts: 4 PRO
edited December 2018 in Community Support
It's easy to make a flange, and easy to make a flange narrower using "modify face".  But what if I want to turn a long flange into multiple lit, like this:
https://cad.onshape.com/documents/a6bdb34235bb22181c3cdc1a/w/5a554c9c2ff1d2ad9a845444/e/82ee62d57befbaee0630a233
Only solution I can find is to subtract extrude after finalizing the model, but then the cutout doesn't get made from the flattened sheet metal part.
Digging deeper, after using modify face to shorten the first flange, I can make a second flange that goes the opposite direction (blue part):
https://cad.onshape.com/documents/35d308ecd1c5c38187f0df11/w/d036e23a77b982951307a735/e/65d8a0ce1659da40b286d23f
But if I try to make them both go the same direction it fails (gray part).
