How can I make a reverse Fillet?
gavin_precurato
Member Posts: 3 ✭
i was wondering how to make a Fillet that could go inwards, or if that is another option I don’t know about. So it would be rounded, but make a cut inwards, kind of like a “C”
NeilCooke
Moderator, Onshape Employees Posts: 5,912
Hi @gavin_precurato - welcome to Onshape!
You can achieve this by using the Sweep command. You will have to sketch the C shape then choose the edges of your model (presumably for a router) to drive it along and Remove material.
Senior Director, Technical Services, EMEA5
